Hi Ronald,
I’ve replied to your other email to me directly but thought I’d echo my reply here in case it helps others who may be having the same issue.
I think your link verification error stems from the fact that you have two multi-price select list items (Mals calls these productpr items) in the buy form. The Mals cart only supports a single productpr in each form item as they specifically set the price (and therefore hash code) for the product. Having two (or more) simply upsets the cart as the hash no longer matches the selected product.
The solution in your example is quite simple. Because the product colour doesn’t change the price we can simply append the colour selected to the item description in the cart. to do this simply use the Inspector to name the menu product1[] and remove the redundant multi-price select Action. When the product is added to the cart the colour will automatically be added to the description.
I hope this helps.
On 14 May 2013, at 16:01, Ronald Botman wrote:
Hope somebody can help me.
I’m using the Mal’s E-Commerce Suite for my website.
See the example link
When I add the LIST/MENU in the article I get the message “ERROR: Link verification failed”.
The Mals’ Add text is working.
Anyone has experience with this and know how to solve this?
