I’m using Mals Multiprice action (V1.5) and it doesn’t seem to be working…
I’ve followed the instructions where by a html table item is drawn and Mals “Buy Form” actions applied. Within this I inserted the List/Menu item and attached the “MultiPrice” action. Example here…
http://www.roarimage.com/uploads/pay
When the Carts tested the Description and the price are taken from the parent “Buy Form” action instead of the optional items enclosed within the child item/menu action.
Any assistance will be greatly appreciated.
Thanks.
Scott
I think the answer lies in the Example store where it says:
In the Actions Palette for the accompanying Freeway file, note how the Actions on the two lists are set up differently. You can have as many menus with options as you need, but no more than one should affect pricing.
In your example both have price options
Have a look at the demo store http://www.freewayactions.com/malsexample/index.html especially the Advance Form http://www.freewayactions.com/malsexample/advanced.html
Thanks David, I’ve sorted the issue now.
I applied the MultiPrice action to the List/Menu item and then entered the details into the item rather than the action itself. The description/quantity/price will now be applied to the Cart.
Happy days.
Scott
