Philip
(Philip)
#1
I work with mal’s shop
When an order is placed, his shop page is shown as insecure.
He writes:
You need to edit the links to the cart on your website so they start with https instead of http.
How do I do that ?
On page source I see e.g.
http://ww8.aitsafe.com/cf/add.cfm?userid=…
The only place I can imagine is:
In the Actions palette for the E-Shop Settings Action, there is a popup menu titled Cart:
But, there I cannot change anything without catastrophic results.
So any ideas?
Thank you very much!!!
Hi Phillip,
I had the same problem a little more than a week ago, and Jeremy helped me with this another thread:
https://freewaytalk.softpress.com/thread/view/176783#m_176791 https://freewaytalk.softpress.com/thread/view/176783#m_176791
Basically, the only thing you need to is to install that action on each page of your website.
Here’s the link for the action that Walter wrote:
HTTPS Helper - ActionsForge https://actionsforge.com/actions/https-helper
However, also make sure to call your hosting and ask them to enable the SSL in your website.
Hope it helps.
Best,
Marcus
He writes:
How do I do that ?
So any ideas?
Philip
(Philip)
#3
This works perfectly Markus
Thanks a lot
Philip
Hi Philip,
I’m glad to hear that!
Best,
Marcus
Thanks a lot
Philip
