Usually, when you are dealing with stock levels, you are eventually drawn to a system that you use in both your stock-keeping operation and your point-of-sale and your Web sales. One database, one source of truth for inventory, and no double-entry or double-effort required.
Mals doesn’t try to bite off this side of the sales problem – they are after much lower-hanging fruit than that.
I have built these types of systems for people in and out of the Freeway community. It’s not cheap, but if you have a sales process that relies on accurate inventory information (say you maybe only have three of a thing ever, like berths on a yacht cruise on a certain date), or if your volume is high enough that my fees are nothing but a rounding error on what you would lose if your customers became disenchanted by not being able to buy what they want right now, then that makes a lot of sense to do.
When you’re stuck in the middle of those extremes, you will either decide to invest in a solution ahead of being able to afford it, or use your “sweat equity” to prop up this hole in your more affordable cart system.
I hope that Tim can engineer a solution for you that keys into Mals and Freeway. But if you want the larger solution, I can help you there as well.
On Jun 11, 2014, at 4:19 AM, Tim Plumb wrote:
Hi Doty,
The Mals cart doesn’t natively have any concept of stock control so it can’t automatically disable buy buttons by itself. I think if you had to go through the site and apply a script to various items in your Freeway document you may be inclined to simply unpublish the buy button and add a simple label that says the item is out of stock.
the think about the current script is that you set it once and it’ll apply itself to all buy buttons it finds in the site. It is a very general script and may be too broad in places but the benefits are that it hardly needs any manual setup.
I’ll have a think about this as I could add an option to the existing Mals Actions that keeps the item on the page but lists the item as temporarily unavailable so can’t be purchased.
On 11 Jun 2014, at 00:54, Doty wrote:
I’m just thinking that something like what I’m doing on my individual pages would be awesome to apply to individual items for example when an item is backordered. Then, when it becomes available again, I could remove the extra code and have a functional buy button again.
