[Pro] manadatory form fields
Hello all.
Can anyone help? I am using a php form action but can only seem to make the email field mandatory. Ideally I would like this rule to apply to the name, tel and message fields also.
Can this be done using the php feedback form action does anyone know?
Thanks in advance
John
Use the Validate action. Apply it to the form fields you want to make mandatory.
Nathan Garner
http://www.austinwellsdesign.co.uk
FW5 Pro | MacBook Pro | Snow Leopard
On 22 Dec 2010, at 14:00, John Balodis wrote:
Hello all.
Thanks in advance
John
Thanks - when I select the form fields the action disappears from the action palette. It is a page action - does it work automatically or am I missing something. Appreciate your help
JB
No it’s not a page action. Select each field and apply the action to each field individually.
Nathan Garner
JB
The page action ‘Validate Extras’ is where you can customise the validation messages.
Nathan Garner
JB
Great brilliant! Cheers Nathan!
John
