[Pro] Map Area Problem
Hi Everyone,
I am trying to resurrect an old FW site. It makes heavy use of the map area tool. In the past, I’ve never had a problem with it. But now, whenever I click on anything that uses a map area there is a glowing line where I have drawn the area map. The line shows up when you click, and if you hit the back button, it will remain almost like a link does with a “visited state.”
This didn’t use to happen, so I assume it has something to do with subsequent browser updates. (I’m using the current version of Safari and have not yet tested this issue with other browsers).
Eventually, I will update the entire site. But in the meantime, I’d like to fix this irritating problem. You can see the issue on the links at the top of this page and also on many of the store items.
http://invertministries.com/store/storemain.html
Thanks so much for your help!
Doty
Any ideas on this one?
Thanks in advance!
Doty
