Hello. I know this is possible because time ago I read this in a post, but I cant find the post now.
I have a master#1, with general buttons, background, legal advice… and I use it to create the pages of the website. Now, I have a set of pages that are based on this master#1, but have some common elements, like specific buttons, an image,…, so Ive created a master#2 and I use it to create this set pages.
Problem: Now I make a change in master#1, that is supposed to be applied to all all pages in the website, but its not applied to those based in master#2…
Is possible to make it? A master based in other master?
No - there is no option to have a Master update another Master.
Maybe this will come with FW6
There are work arounds using includes but it can get pretty complicated.
Fortunately the FW copy/paste is very good about pasting into the same position on different pages.
Thats it!!! Includes!! That was the word!! But you dont recommend it… copy / paste then.
It is not that I dont recommend it - it can be tricky to set up.
