To my consternation and annoyance, two master pages have lost proper association with their pages. I made some changes in the masters, saved and the save took forever. After that, I was forced to reapply EVERY single page content. Most everything works except for a small table nav bar. For some reason, while the links in the table work, I can’t change the text. Or I should say I can change the text but the change doesn’t reflect in the child pages.
on 27/04/2009 03:58, toolemera at email@hidden wrote:
David… I’m not familiar with these two options. Were would I find them?
Select the item [that is not updating from the Master Page] then in the
“Inspector Palate” you’ll see the top two items, “Use Master Content” & “Use
Master Settings” with a check boxes alongside.
Best wishes Peter
Peter Tucker, Oxford UK email@hidden
