[Pro] Master Page/Item Question
I remember in Adobe GoLive you had the option of using snippets, or something, where you have elements of your site like a nav menu in a separate file and when you alter it it updates on all the pages it’s on.
I alwasy start out using Master Pages then somewhere along the way everything goes “pear-shaped” (I think is the Brit term!) and the pages don’t update correctly.
How would I update several Master Pages with only partial common content, such as nav menus and footers?
PS I’m still in Pro5.
Thanks.
Bob
There are actions like ‘Use Simple Include’ that can pull content from one page into another (or several) and display it there.
