Hello, Together,
if somebody has of you an idea as one can move the following (I think of Rollover or of the crossing action tools)
Function of the menu strip:
By a click on an arrow (badge) a side strip should appear with the menu overview where the side links are selectable.
A renewed one press to the side strip it steals against
Hello Dave,
please see the link.
With the rollover tool I get the effect but not correct ,the side bar is not moving back.
And also how I must added then the HP menu with links on it?
Not only are you using the script/protaculous and jQuery libraries but you have over 40Mb of image files.
Do yourself a favour and shrink those big images down to something more manageable - I would suggest less than 300k each. Change your file names so that there are no space characters or any other punctuation in your file names. Stick to _ underscores and - hyphens and alphanumerics (A-Z, a-z and 0-9)
Cut the page down to just the essentials so that we can see what your menu is supposed to do and then we can take it from there.
