Is it possible to create a css-menu which appears upwards instead of downwards?
If yes, how. Was not able to build one until now…
Not using the CSS Action, no. I suppose you need to separate the menu/submenu items to different div’s in order to make that work. It can be done.
Though not exactly what you are looking for the BAM Menu action might help you towards what you are trying to achieve - but that will really depend on the complexity of your menu
Try this;
http://www.freewayactions.com/test/css-sub-menu-position/
