Hi - can anyone help me with what I need to do to insert photographs so that may 4 or 5 pictures show in a loop - one after the other?
Howard
The Showcase action will do this for you.
Or you can use the Sequence Timer action
Also ScriptyFader available from actions forge.com
and Newsticker if you want other stuff in there too http://www.deltadesign.co/newsticker2.html
There are many ways to achieve this and if you can show us an example of the effect you are trying to achieve we can point you in the right direction. Or even just a description.
Another example http://www.deltadesign.co/examples/imacfader.html
And is if you haven’t had enough of me there is a Podcast available on iTunes called ‘Scriptaculous Slide Show in Freeway 5’ - if you search for Freeway Moments there are all sorts of Tutorials there on various FW topics.
Thanks Delta Dave - really appreciate your help - I have made a start and will follow up re. your other advice.
Thanks again,
Howard
