This looks great - quick question, does this replace the meta data thats already on the page? If so Ill delete whats in the Meta data (Page/add Meta tags) - Or does this mix with whats already there? I’m going to use it but need to know if I have to copy and past out of the already existing meta and place into the Meta extra action…
Hi Justin,
Unfortunately targeting specific meta data from an Action can be a bit hit and miss. At the moment the Action will happily replace the content of the title tag but will blindly add duplicate meta data if it already exists in the page. Until i can figure out how to reliably search and replace this data I would suggest either adding your meta data with Freeway or the Action but not both.
