I cannot upload my site to the server which gives the error message
Mkdir command failed
comments why welcome
regards
Mike
regards
Mike
-----Original Message-----
Sent: Friday, January 22, 2016 6:55 AM
To: email@hidden
Subject: [Pro] Mkdir command failed
Mike
Assuming that ‘Mkdir’ is really ‘mkdir’ and the capitalisation is a feature
of your emailer, it’s an ISP problem. They’re not likely to talk to you
properly if you’ve only tried the FW upload to make that directory, so grab
a third party FTP client, or use the ‘ftp’ command in Terminal if you’re up
for it, and try to make that directory manually. If that doesn’t work, call
your server ISP as you’ve now got two methods that don’t work.
This email has been checked for viruses by Avast antivirus software.
