I’ve got a problem. Have just loaded some images on to the home page of http://www.brutontown.co.uk and used the moo:Slimbox v1.1p3bug-fix1 action.
Problem is it does not work in the way it should do. When I preview in Safari, the action works fine. When loaded it’s just one vertical column, Auto Generated Gallery, and at the end it says ‘It appears you have Javascript disabled. Please enable for a richer browsing experience.’
Have checked in Safari and I do have Javascript enabled.
Is there still a bug or am I missing something. I did have another page with this action, slimbox/lightbox on and that has stopped working in the way it should.
Panic over, I think. Have just reloaded the site and Slimbox is working in a fashion.
Problem I’ve now got is that it’s not loading all the images. The main action has 11 images, inserted another action item titled ‘link to lightbox’ and added another 4 items. It’s these last 4 that don’t load. Group name is ‘bruton’
