[Pro] MooTools Accordian & CSS Menus
Hi Everyone, I have a question?
I have combined the Mootools accordian action with the CSS menus at the following URL (http://www.mpscreative.co.uk/client_folder/pts/index.html)
This is a crude example and is not styled or functional yet.
My question is; Is this good practice or is there a better way of doing it?
The reason I have done it is to get the background hover effects that are possible with the CSS menu action.
I would be grateful fro any help on this.
Many thanks
Mark
Sorry meant to say that the CSS menu has only been applied to the top menu item.
Mark
Yes i was playing about with something similar - http://www.deltadesign.co/accmenu.html
The difference being that I used ScriptyAccordion which works happily with the Script/Protaculous based native FW actions because there can be conflicts between them and Moo.
And especially for navigation - which will appear on every page - they (Moo and Scriptaculous) shouldn’t be used on the same page.
Thanks David, I’ll keep them apart.
Mark
