I applied Weaver’s MooTool’s accordion action to a table: One cell contains the accordion trigger, an other cell contains the content. So far anything is working well as expected.
However… when moving the mouse over the accordion trigger’s text, it does not change into the “hand” as done on normal links nor does the text change its appearance (as hoovering over a real link).
This may confuse some users since they don’t think that there is anything to click on. Is there a way to fix this ?
The pointing hand should appear when a person is viewing the page with JS enabled AND you have ticked the ‘Make into Typical Link’ for the Accordion Trigger.
This is by design to help PREVENT confusion that, when JS is disabled, there is nothing that will happen when the accordion trigger is clicked anyways. No click event, no pointing finger.
Let me know if the above information does not help resolve your observation.
@weaver: The option “Make into typical link” is greyed out, but checked.
I also experience the problem that (although “remember state” is enabled and cookies are accepted) just sometimes the accordion state is really remembered. It doesn’t work reliable. Anyway, all in all it works and it seems that the cookies are set (checked it with SeaMonkey).
When viewing the source code, I have some strange entries within the head section: Two JS calls to external .js files are pointing to non-existing directories.
Do you mind having a look at my FW project file ? I sent it to your address actionsupport at gmail.com . Likely I just made a small mistake that is responsible for this trouble.
(Sorry if my message appears twice, but it seems that my first reply wasn’t taken over…)
