Just putting finishing touches to my first e-commerce sight, I have used Mootools accordian to create a drop down menu etc.
I also want to use sequence timer with fading layer action on the same page, but these two clash.
I have trying to have revolving advert panels on the page, 4 in total.
Anyway around this or any other action that will do a similar thing without staring again with the drop down menu.
No. You’re going to have to find a Moo-based effect to do the Fading
Layer bit, and you’re going to have to hand-code that into your page.
Moo “forked” away from Prototype.js a number of years ago, but they
kept certain function names and working methodologies from the parent
project. As such, the two are completely incompatible, because those
names and methods mean different things in both projects. Freeway uses
Prototype internally for a number of its Actions, and all of my third-
party JavaScript Actions are based on it as well. Weaver has some
Actions that use Moo, you might want to have a look over at http://coastalrugs.com/Actions
On Nov 7, 2010, at 12:17 PM, Mike Thornley wrote:
Hi Guys
