I’m not quite getting what you want to do here. Do you want these
trigger elements to be the heads that open and close the rest of the
accordion, or do you want these triggers to be within the element of
the accordion that gets disclosed when you click on the head?
If the former, then use ScriptyAccordion, and use the Text Rollover
Action to create the heads, like this:
[type a single space][insert Text Rollover Action][type a single space]
{type a return)
Now highlight the entire line (including the return at the end), and
apply one of the header tags (I like an h3 for this).
Type your disclosed information below that, in a separate paragraph.
Then repeat the header/paragraph construction until you are done.
Apply the ScriptyAccordion to the nearest HTML box outside of this
list (its direct parent) and configure the Trigger Elements to be h3
and the Show/Hide Elements to be p.
Each Text Rollover can be configured separately to trigger one of the
Target images, and you set this up in the usual manner of making a
group of rollovers affect a group of targets. Text Rollover is also
responsible for the actual text that will appear inside each header.
You enter this within the Actions palette.
The ScriptyAccordion Action doesn’t particularly care about what link
(if any) is inside one of the headers it’s watching, so it should
continue to work independently of the Target Show/Hide stuff.
On Apr 29, 2010, at 4:50 AM, scoutdesign wrote:
Does anyone know of a way to use either Mootools or Scripty
accordians together with Hide/Show layers. I want the effect of the
accordian, but to show and hide layers on the same page. I know they
use different scripts that don’t currently work together, but is
there another way.
Mike
