I wanted to know if anyone can tell me if there is a fairly easy way to have someone mouse over my 24 icons and when they mouse over each one, a little bubble comes from the icon telling what it is about?
I was going to use target show/hide layer and have the text appear somewhere else on screen but space is at a premium and thought maybe the bubble thing could be cool and save space.
Then in my example I have added the class:tool to item extended of the Img that has the link and the Alt text of that image is used as the tooltip text.
I uploaded the unitip folder to my root.
I put the reference in my before /head section.
I changed the url’s in the reference to match the path on my website.
I added class:tool to the images in Extended.
So I think I’m nearly there, but since I do not see the effect I think I need a little more help.
Ahhhh!!, I changed the location of the images and changed the path to the images to everything it can be (absolute, relative etc) but still the images are not showing. Is there any other location than the CSS file where I should change the path to the images?
Well, this morning someone with a lot more skills checked what was wrong. The unitip folder and it’s subfolders has some issues with read/write rights. Now I point everything to the Resources folder and now it works.
Because this thread and the other one I was directed to contain a lot of important and scattered information I decided to put all the steps into one tutorial on my website. I hope this makes sense and can help others to achieve this effect too, but a bit faster and easier
Yes, you can prepare everything before you go live. The only thing is that you can not see it working, because for that it needs the website to be in the same folder the unitip folder is in (the root) and where the code is pointing at.
