Can anyone explain this? When I create an HTML, CSS-defined box with round corners, whether the box is solid or just an outline, it previews perfectly in Freeway but when I view the same item in Safari or Firefox direct I’m getting multiple versions of the corners and the top and bottom graphics, stacked vertically.
This is really bothering me because I cant see any anomalies in the code. Is it a browser rendering issue or is there something, such as a plug-in, which might be causing the problem?
Cleared the cache so many times I can’t count…
I’m going to have another go but only yesterday I started designing a new site exactly the same way and it previewed fine and then went screwy when I viewed it in Safari. It hadn’t even had the opportunity to have been cached.
