Has anyone used “My Maps” in Freeway Pro?
Will it work with the Google maps action?
Thanks John
http://www.lovelandbiketrail.com/LBT.directions.html
What is “My Maps”?
Dave
It is a Google map service. My customer uses it on his old site and wants it on his new site. Just have to figure out how to use in Freeway Pro. Thought someone had experience.
Thanks John
John
You need access to your clients’ My Maps.
You can embed your own map, or a map shared with you, into your website or blog.
Open the map you want to embed and make sure it’s visible to the public.
In the left panel, click the map menu button .
If the map is view-only, click the share button .
Click Embed on my site.
In the box that appears, copy the HTML under “Embed on the web,” and paste it into the source code of your website or blog.
Make your map public
To allow anyone to see your map, set your map’s visibility to “Public on the web.” Or you can allow just certain people to see your map. Learn more about sharing your map.
If the map isn’t yours, you may get an error message telling you to select Manage Permissions from the sharing menu . This will allow others to view it.
You can add this code to your page where you want the map by using Crowbar or Add Code actions
Kevin
Kevin
Thanks, probably makes the most sense for me to set up an account and use my own maps. Will give it a try.
John
