Please help me with a tiny problem. I would like to link the “Home” (default) in my navigation bar to my index page. I have tried to hyperlink the whole nav bar, but that didn’t work.
Is it even posible to link the “home” otherwise I might do as I did first… creating grafical items on each page and link the text… (take to damn long when the site is big…)
The same principal applies when making any link in FW - select the item (whether graphic or text) and apple K (Edit>Hyperlink) to bring up the hyperlink selector.
The Internal tab shows all the pages in your site while External gives you options to create links to other sites.
It makes it easier to recognise your different pages if you have given them meaningful names.
Thanks for you replys, I don’t have a link, (hate not having), but my boss is doing all the publishing online.
I did forget to tell you that Im using the Action called Navigation Bar.
So this means that I can’t highlight/mark the “home” in the Navigation Bar, I can create a hyperlink on the action it self, but when I click on the “home” in the Navigation Bar online it still doesn’t take me anywhere.
Do I need to make changes in my folder structure in FW to “activate” my “home”?
As soon as the page is published I will give you a link.
