I’m using the Navigation Popup Action and it works as expected, except I cannot return to my Home page no matter what. When I go to the Navigation Popup from any page, Home Page is preselected… I’d expect the current page to be so. But no matter, so it’s on Home Page and I hit Done and it goes nowhere. I can select other page targets, just not my home page. Any suggestions? Thanks!
This is a known issue with this type of navigation. It relies on the picker (select element) sending a “change” event, and if the default is the home option (basically, because the selected flag is not set on any of the other options) then it never happens, because home is not a change from where the picker started out. I’m not sure what if anything you can do about this. Does the Action include any options around “show current page selected” or anything like that? If so, and you enable that, it should work for this situation.
