[Pro] Navigator preview
Hi,
I am starting using Freeway and I started with a rollover button. It works all right in Freeway but I have a different result between Safari and Firefox. Firefox is correct but not Safari. Any leads ?
Thanks.
If you can show us an online example we should be able to tell you why but without more information it is difficult to guess.
Everything is all right now, I could not exactly tell why though. I used the Publish menu, maybe that helped. I am really new to this so I understand little by little how things work and it seems to be great indeed.
Anyway, you made me set an online file so I could test my pages. It will be a lot easier.
Thanks again.
Quite often, especially if actions are involved, you will only get a true representation if you view online.
