Is it possible to edit out links in the site map action in Pro 5?
I have a few pages that I don’t need showing. As the site has over 400 pages, I don’t want to type in a site map page.
There’s an option at the bottom of the Site Map Action labeled:
Omit Pages and Folders beginning with:
Check that option and choose a character; the default is the “_” (underscore) character. Now select the page you want removing and change their file names in the Inspector so they start with the character you chose previously. To change the name of a folder you need to Option click in the Site Panel.
Hope this helps,
On 4/21/10 12:17 AM, “Joe Billings” email@hidden wrote:
Hi John,
Hope this helps,
