I just downloaded the trial version of FWP5. I like it so far but I’m not convinced the price is worth it compared to Sandvox, Rapidweaver, and Iweb. Just thought I would ask the opinion of those who have used FWP and these other programs I mentioned. Personally I use and like Sandvox more than any of the others. What makes FWP so much better?
If you want to build web sites from scratch and build “virtually anything” and you want from a “start with a blank page” and use your own styling skills then Freeway is the way to go.
If you want cloned templated sites (yawn!) then Sandvox, RapidWeaver, iWeb might be a better choice for you. (Although Freeway does have templates to choose from).
Ask yourself where do you want to be in a few years? Making templated sites, or building your own web design creations.
