Peter2
(Peter)
September 15, 2015, 4:25pm
1
Hi,
does anyone know of how to keep the header at the top of the page in a responsive site and the footer at the bottom of the page?
So on an iphone the menu and the header would always be visible at the top of the screen and a small footer would always be visible at the bottom.
I have lot of images on one page and have to scroll all the way to the top to reach the menu.
Or is there another wayround this/
Thanks in advance.
Peter
Simplest way is to use Position Fixed but there are numerous others.
Keep both of these visible all the time and it doesn’t leave much room for your content on iPhone. I would reconsider the footer.
Peter2
(Peter)
September 15, 2015, 9:01pm
3
Hi David,
thanks, is that on the inspector palette?
will give it a try and consider losing footer.
cheers
Peter
It is if it is not an inline construction.
If you are building inline then look at Walter’s Sticker Action http://actionsforge.com/actions/sticker
If it isn’t positioned absolute, to be pedant … and if it is an inflow-item (positioned relative), select the item - chose item → extended and add to the
<DIV Style>
the following name/value pairs
position: fixed
z-index: 999
top:0
left:0 /* optional if it stretches all across the browser-window*/
right:0 /* optional if it stretches all across the browser-window*/
width: 100% /* optional if it stretches all across the browser-window*/
A tiny lil Action applying those attributes to an item isn’t necessary, but would be outermost helpful!
