[Pro] New Fonts HTML
If you are using a non Web safe font like Helvetica Neue then you will get unexpected results unless the font is present on the viewers machine.
thx David oh well too bad
ok I tried helvetica but I like the Neue better so I will make PS and import jpg image. That would be fine correct?
I know its extra work but the look is nicer for my purpose
Thx
Why not use Helvetica Neue as graphic text - you will much better display than PS will give you.
A GIF would give you a sharper result than a JPEG.
best wishes,
Paul Bradforth
Buy my eBooks at:
http://www.paulbradforth.com/books/
Sent
of course thx
