Dear Freeway users … I am new to html and created a page to be used (pasted) into an online pool supply store. I created a test page and it looks pretty good but does not size up with the template I’ve pasted it into.
see link: http://204.12.111.231/home.asp
I also can’t get the image to appear (sauna1) although I’ve inserted instructions just before the image to direct it to the file storage area of the online pool store website. I checked out other pages (viewed the source code to determine where to insert the “our folder for uploading the files is located at: /custom_images”) and the image does not appear.
Any advise would be very appreciated. I checked out more than 5 html programs before selecting Freeway Pro. I believe Freeway Pro is the most user friendly / powerful application for my purposes.
Thank you in advance for any assistance you may provide.
Rgds
Dennis
Hi All,
I have figured out most of what I had questions about earlier.
Anyone interested in helping me create some editable templates for my online pool store … $$$
Rgds,
Dennis
You say you’ve created a whole page if HTML code, and then inserted this into another page?
Freeway is designed to create the whole website in it’s entirety (code pictures, structure) to upload to your server.
If you’re doing anything other than that you will run into problems.
Eg it’s not intended to be a HTML snippet generator
David Owen
Rgds
Dennis
