New to FW so I’m not quite sure how to share links, hope this works.
Nope - that wont work as that is a local link ie the path to your file on your Mac. Which is not accessible over the internet.
You will have to upload your page to your server and then share a URL with us.
If you create a subfolder in your current site ie yoursite.com/mytestfolder and upload your FW site into that then we can have a look.
dynamo mailing list
My current site is built on a PC on BlueVoda which does not have a Mac version. Not quite sure how to share and although the Master page is progressing I am still having some issues.
Marcie
dynamo mailing list
You will need to use an FTP app to go into your server and create a new folder such as yoursite.com/mytestfolder
In the FW upload dialogue box you would enter whatever you normally use to upload your BlueVoda site and add on /mytestfolder in the directory section so you would get something like:
Server: www.mysite.com
Directory: /public_html/mytestfolder
User name: yourusername
Password: yourpassword
Web address: http://www.yoursite.com/
Now if you have created the folder on your server using an FTP app when you use FW’s File>Upload your test pages will be uploaded into the folder called mytestfolder
dynamo mailing list
Question: How do I get drop down title bar menus to open over another graphic box? Mine are publishing at the front no matter where I put them.
Marcie
dynamo mailing list
Sorry, figured it out! I’ll put something up in a day or so. Thanks.M
dynamo mailing list
