I think the only way for transparency would be to have Exhibeo output the
slides as transparent pngs instead of jpegs, which don’t support
transparency. The problem with that is pngs are notoriously large, and
would slow the whole page down.
You might try reversing the direction of color sampling… it’s a little
tricky, but let me outline a possible approach…
Jpegs are RGB color, but Freeway Pro uses Hex values to describe colors –
so maybe our FWP hex color (#202020) isn’t able to get close enough to the
jpeg slide’s RGB color (48,48,48).
Try this:
In Freeway Pro, open the Style Editor. If there is not already a Tag style
named body then create it. Remember, Tag styles have their name in the
Tag field of the Style Editor with the Name field usually empty. Now open
the Extended attribute dialog and create a new attribute:
Value: rgb(48,48,48) !important
Exit the Style Editor and republish, then Preview.
On Thu, Feb 7, 2013 at 11:41 AM, Ken email@hidden wrote:
Hey thanks Ernie! I do appreciate the compliments.
Through the method you described is how I came up with the current color
for the padding/background.
Let us add NO COLOR backgrounds it to the list for a future update.
Great minds think/drink alike.
Cheers!
_ken
Exhibeo mailing list
