A problem has occurred!
When I try to remove styling used on an HTML page, by clicking on [No Style].
Instead of just removing the styling as normal, it now goes to a much larger font (size 36) which I have used elsewhere on the website!
I have reloaded Freeway and trawled through all of the settings but have not been able to solve the problem. The problem does not occur when I make a new website.
Your 36pt style has been inadvertently been applied to a parent
element of the item. Styles can be applied to either containers or to
text (well, strictly speaking, to the container element of the text –
either a span or a paragraph or a header or a list item).
Try clicking on the parent HTML box of your text, and see if your
style has been applied to it. If not, then try clicking on the page
itself. Another tool for this purpose is the “cascade” view, found in
the Inspector. When your text or parent element is selected, look for
a tab with a ( T ) icon. You should see a list of all the styles
currently applied to that element.
[No Style].
