If I publish my website (command U) and I zoom in a little (command +) than I see in the grey background a lot of noise, very irritating. The strange thing is that when I look in the previwe mode in Freeway there is no noise at all. Is there a solution to this problem ??
what about “bilinear” and “dither” ? should they be checked or not ? If I put AA to “off” the quality of characters become bad. So i put it back to auto. I had this noise problem before and asked you then as well. You told me than (if I remember well) that it has something to do in what order the layers are stacked. However forgot how this advice to implement. You remember this ?
I don’t remember saying that stacking order was a factor.
What is a factor is whether or not (in Auto mode) FW is aware of exactly what colour to AA against.
I would pick one of your items where it is worst and try setting the AA colour manually choosing a colour that is as close to the background as you can get. You may have to use the colour picker tool for this ( looks like a magnifying glass)
As I am not back at my computer until late tomorrow I cannot look at specific examples for you.
Honestly, I have no idea how you inserted it (Graphic Item?).
If so - please check the graphic settings in inspectors field.
Anyway, I’d recommend to add these kind of graphics as “background” for the div named “grijsvlak”. This would enable you to really rate, if noise is caused by “the image” or “the machine freeway”.
