I am using a website that lets me write on screen and record. then saves the link so I can send to my students. Here it is…
I am using a website to make quizzes and I can type the answer explanations but they let embedding (probably meant for video).
Is there a way I can embed the sketch site page above so the drawing appears in the answer explanation box? There is no mention of embeding on the sketchtoy site.
What sort of options does the quiz site give you for embedding? Do they allow raw HTML code in the answer section, or do they filter that out? If they do allow it, you might try using an iframe to place the sketch. If you have a URL that will show the raw sketch, you could try adding this code:
