Have a bit of an odd situation. I pulled up an existing FW file and was going to make some changes to it. Files, fonts, etc… however, when I make the change and preview, the old images are displayed. I refresh, same thing. I’ve previewed in my browser, same thing. I’ve even deleted images and they still appear? I’ve cleared my browser cache as well, with no success. I’ve used FW for many years but never had this issue? Any ideas? Many thanks!
One other note, I deleted all of the FW prefs, rebooted all but still no luck. I also previewed in other browsers (Safari, Opera) same results. Its as if the changes that I make in FW happen only on screen and not in the actual file.
Are you sure you are previewing the correct page?
If you change a Master and preview then the first page in your site will be displayed - whether or not the Master changes were applied to the child page.
Other than that if you post a link to a page online and tell us what we should be seeing we can tell if it is a Browser Cache issue.
This is a screen capture of what it ‘should’ look like… Dropbox - Error
This is a single page email blast, created in FW. There is no master.
It views incorrectly in PREVIEW mode as well. I have used multiple browsers to view, deleting caches, restarting FW and the MAC, deleted all FW prefs and finally reinstalled FW (fresh copy) all to no avail. I have never had this problem before. Its as if Freeway is not refreshing the code once I make changes within the document.
Another oddity that I’ve noticed… I cannot change the FONT using the INSPECTOR window however, I can using the drop down FONT option under STYLE. Strange?
*UPDATE Okay… it is not a FW issue. I went to another machine to view this post, clicked on the link to the working file and… it appears as it should. I obviously have a cache issue somewhere on the mac causing me to see the old data.
