Lode_Rosel
(Lode Rosel)
January 15, 2012, 8:08pm
1
Hi,
Is there a way to make SNW “mouseover” instead of “clicking” more “permanent”?
I can change this in the “html file”, but when I work on that page again, FW overwrites the file and all is back to “onclick” status.
My client wants to make is pictures visible on mouseover. I use “show/hide layer” now, but the effect is not as nice.
Thanks, Lode
Are you trying to get a lightbox type effect on mouseover?
Lode_Rosel
(Lode Rosel)
January 16, 2012, 12:46pm
3
Hi,
Yes, something similar. I prefer SNW (iPad mode) because it is very responsive and opens very fast.
Lode
Lode_Rosel
(Lode Rosel)
January 16, 2012, 2:34pm
4
edit
I tested “Scripty LB2” and this is much faster than “LB1”. Using SNW involves the creating of a lot of pages, is that effecting the site in any way?
Thxs, Lode
Lode_Rosel
(Lode Rosel)
January 16, 2012, 2:42pm
5
edit 2
Just noticed that SLB2 does not “fade out” the background, and that is an effect I need.
Lode
Paul4
(Paul)
January 16, 2012, 3:19pm
6
Right now, SNW does not off the MouseOver event. It’s an interesting idea, marred only by the fact that there is no equivalent to “mouseover” event on iOS devices. It’s click or nothing (think: am I touching the screen: yes or no?).
Lode_Rosel
(Lode Rosel)
January 16, 2012, 3:38pm
7
Hello,
I just tested it on an IPad and touching the SNW (onmouseover) link opens a new window, but without the “floating” effect.
Lode
Lode_Rosel
(Lode Rosel)
January 16, 2012, 3:48pm
8
edit
correction, maybe my SNW window is to big to show properly on the iPad, I change it and give it an other go,
Lode
Lode_Rosel
(Lode Rosel)
January 16, 2012, 4:27pm
9
It’s not working properly on a iPad, “onmouseover” opens first just the page, if you close this the SNW is on the screen.
Here is the test site, left image “swimming pool” is the “mouseover”, hide/show layer (red square) works fine on the iPad.
http://www.roselnet.com/
Lode
