I received code to use from the Better Business Bureau for a client’s website and tucked it in a mark-up item. Works fine, as shown in the included page. The only issue is that it doesn’t open in a new window, which I’d very much like it to do. Is there some place in the code I can add to the markup item to make that happen? I never like taking people off a client’s actual site.
Note the leading underscore in the target value – that’s significant.
In HTML5 (XHTML 1.0 strict) the target=_blank is disabled (thrown out?). For a couple of reason I can understand why - on the other hand I like it, but only for links that are “leaving” my page. Am I telling something wrong and would do you think about?
I feel personally that you (the page author) do not have control over my (visitor) browser. So I actually like the removal of target for this use-case. If I choose to invoke my browser’s command to “open link in a new tab”, then that’s my choice, not yours, to make. However, the restriction of target has been removed from HTML5, and that’s the future, not XHTML, so it appears I have been in the minority all along (no great surprise to me).
The primary issue with target="_blank" is one of usability. That new window does not carry any history forward from the window that spawned it, and on Windows computers, the default is to open a browser window full-screen, so you don’t even have a visual clue that a new window was opened. You try to go back to the previous page (because there wasn’t any warning that you were going to open a new window) and you can’t. Back is “broken”. Only if you are clever enough to look through the tabs along the bottom of your window, and see the previous page there among the hundreds of squished icons, will you ever find your way back.
On Oct 8, 2012, at 10:25 AM, Thomas Kimmich wrote:
Good point Walter.
