I am trying to use Intaglio 3.5.1 to open files created with Intaglio 3.4 and I keep getting the following error:
Error: The current style is locked.
File: StyleContainer.mm
Line: 738
Have you experienced something similar? Do you know if I can download a previous version of Intaglio? At the moment I have essentially lost the possibility of opening all the files I have edited in the past.
I contacted the support email address and Nick replied that he hasn’t seen this issue before, so he asked me to provide him with a suitable file to reproduce the problem. It is then reasonable to expect that he is or will be working on it
Nick drew my attention that Intaglio 3.4 can still be downloaded from the Intaglio webpage, which I hadn’t noticed. I am back on 3.4 at the moment and I am waiting for a bug fix.
5 months after this thread and I’m running the current version (3.5.4 ) but can’t open a file from (3.4.2) on my old computer. Error: Intaglio can’t import this file.
File: StorageContext.mm
Line: 351
I am able to save the old file as a pdf in 3.4.2 then open it and make it editable in 3.5.4 however the layout measurements & scale is gone, so not useful for a drawing done to scale.
Hope this bug can be addressed to make the migration more seamless!
