[Pro] OSX 10.5.6 update and Cursor issues
Anyone updated to OSX 10.5.6 ?
I’ve noticed that Freeway at some seemly random point permanently displays the Magnifying Glass as the default pointer icon.
Only a re-start seems to fix it.
Any one else awarer of this issue?
Hi David,
Do you mean 10.6.5? I haven’t noticed this problem, you sure you’re not holding control and shift, or have the Zoom tool selected when it happens?
…no keys selected but the cursor remains as the glass, I can select text OK, and swap tools.
Ah, hah… Photoshop contrains a brush paint to horizontal/vertical , so its like you say holding control and or shift (but not actually doing so).
weird.
This is the 3rd time its happened since updating to 10.5.6 yesterday.
Only a re-start fixes things.
On 16 Nov 2010, at 12:59, Joe Billings wrote:
Hi David,
Its done it again if Freeway . This is so annoying, when starting up Photoshop it asks to delete the preferences.
Its like OSX is holding the control-option-shift down permanently.
Hi David,
Do you have a different keyboard you can try?
Hi David,
Tried that and it’s not the keyboard. Or pressing shift 5 times for sticky keys as someone else suggested.
Today there is no Freeway work and the problems is not present yet on any app ~ perhaps because Freeway has not been opened? I’m going to open Freeway later and see if this causes the issue again.
Hi David,
Found the issue:-
Using ctrl-alt-space for Cultured Code’s Things quick entry window make the keys stick permanently in OS X 10.6.5. For me at least.
Glad you found the problem. I did think it was unlikely to be Freeway causing it :smiley:
On 24 Nov 2010, at 11:51, David Owen wrote:
Found the issue:-
Seems its an OSX issue with CGEventPost(kCGSessionEventTap, …);
Whatever application uses this API may trigger…
Not just me with the problem a 10.6.5 problem
Found the issue:-
Jesper Storm Bache has kindly posted a small app on one of Adobe’s forums that works around this bug in the CGEventPost API in 10.6.5 by resetting the option, shift, command and control keys:
http://www.bache.name/download/osx/10_6_5%20keyboard%20hack.dmg
Found the issue:-
