Hello all.
Does anyone know if it is possible to make an inline div scroll with overflow on iPad?
Billy
Hello all.
Billy
Sure. Select the HTML box that has the Overflow setting applied to it, choose Item / Extended from the main menu, click on the
-webkit-overflow-scrolling
In the Value field, enter
touch
That’s it. Oh, and you must have already set Overflow: Scroll in the Inspector, or this won’t do anything.
On Jan 15, 2014, at 5:35 PM, billy kimmel wrote:
Hello all.
Does anyone know if it is possible to make an inline div scroll with overflow on iPad?Thanks
Billy
Thanks Walter.
