OVERFLOWED TEXT. The following items contain overflowed text which will not be published.
I changed the name of one of my navigation buttons on the Master Page from “welcome” to “home”. Now I get the above message. The bottom right hand corner of the button is turned up different than the others. How do I fix this?
http://www.jvwhealthyfamilymall.com
It is very likely that you didnt delete all the text in the box before you typed in the new text. (Or you have an extra Return in it)
The error message probably told you the name of the item with the overflow on it ie item1
If you change the view at the top of the left hand column from Site>Page you will see all the items on your page listed. Select the name of the one with the overflow until it hilites then hit the enter key. That will put your cursor in the box in question where you can then delete/change whatever is in there so it fits.
BTW - do this on the Master page
