billyk
March 28, 2018, 4:46pm
1
Anyone familiar with Owl Carousel?
I want to make my Carousel infinite. Anyone know what the code option is for this?
http://smartytest.com/Sarah/index.php
The purpose of this topic is to provide information about the migration from FreewayTalk and Groups io to Discourse and the differences in Discourse, as well as a place to discuss the good or bad of the migration. For those previously subscribing...
Reading time: 2 mins 🕑
Likes: 1 ❤
You are using OwlCarousel v1.3.3, you can use the updated version 2.+ and its new loop feature.
See about the Infinite Loop feature in the API options:
loop - Type: Boolean - Default: false – Infinity loop. Duplicate last and first items to get loop illusion.
See the demos page for more usage examples:
Likes: 1 ❤
billyk
March 29, 2018, 12:01pm
3
Thank You for the update.
Billy
Likes: 1 ❤
billyk
March 29, 2018, 1:10pm
4
Well I tried to add the Owl Carousel 2 but I’m unsuccessful.
This version has a few class changes and I’m confused. I’ve uploaded all of the package but I think my div and class names are not correct and where I’m calling the scripts on my page is unclear.
Do you have a freeway example?
Billy
Likes: 1 ❤
You will need to replace the related Owl CSS and JS files to the updated version 2, then modify the references and initialization script as needed.
Start with a basic example and get it working, then modify it with any additional CSS styling you wish to apply to it.
billyk
March 30, 2018, 1:13pm
6
I did this step but still not working.
Here is the page: http://www.smartytest.com/Sarah/index.php
“People are talking”
I can see that the code is creating the Carousel but the divs are not showing. I wrapped them and gave it a class of owl-carousel.
Billy
Likes: 1 ❤
Well for starters in your test, both the references to “jquery.min.js” and the “owl.carousel.min.js” are showing 404 not found. So the first place to begin is getting those correctly in place for testing. Like mentioned earlier, start with a basic example and get it working, then modify it with any additional CSS styling you wish to apply to it.
Likes: 1 ❤
billyk
March 30, 2018, 6:18pm
8
Ok I’ve got the right files now.
Still not working.
Billy
Likes: 1 ❤
billyk
March 30, 2018, 6:21pm
9
I was able to get Owl Carousel V.1 to work fine. Not sure why tis is different.
Likes: 1 ❤
