Jack2
(Jack)
1
I’m having a page length problem with a site I designed.
I have 3 sections. Header, body and footer.
I keep trying to make the page longer by expanding the body section. However, no matter how long I make it, it stays the same, as shown here:
http://shoppingaddix.com/deluxe/catalog.php?new=yes
Any suggestions would be greatly appreciated.
Jack2
(Jack)
2
Just discovered what I think the problem might be…
I installed a Page Action (Source Code Snooper) to edit some code to work with OptionCart.
When I removed that action, everything worked as it should.
It was as if by leaving that action on, it was keeping the page in a static state.
No changes would preview in the browser.
Source Code Snooper is a dangerous action if you are not 100% sure what you are doing.
I suspect you can get what you need with Insert>Markup
Jack2
(Jack)
4
I have to insert a tiny bit of php code at the very top of the Freeway page code (before the DOC TYPE info).
Can I achieve that with Insert Markup?
Right now, I use Cyberduck and TextWrangler to insert the code after the page is uploaded. Kind of a pain.
waltd
(Walter Davis)
5
You can use Page / HTML Markup for this, choose Before HTML using the picker in the bottom left of the dialog.
Jack2
(Jack)
6
Thanks Walter! That did the trick!
