I get a error 404: page not found when I search for my site or it takes to long to load and session times out
Check to be sure that you didn’t rename your index.html (Home page) something else. Note that you can (and should) have a separate Name and File Name attribute. The file name is the important part of this; unless the file is named exactly index.html, you will have to use the complete URL to the page (including the filename). The Web server will “auto-complete” the URL you note below to Flavored peanut butter, raw honey and an apothecary product line – Reid's Gourmet but if that file is missing, then you will get a 404.
Thanks Walter,
It looks like I did change the file name, so I changed it back. Would it make a difference that it is a mobile direct file?
What does that mean, exactly? Whenever you want just the bare domain URL (or bare domain/folder) to work, you have to have a file named index.html inside the appropriate folder on the server. What that file name means to the Apache Web server is “if you can’t find a filename in the URL, use this one instead”. If that file also has a mobile redirect on it, then that’s fine, but not important to the Apache server.
On Apr 3, 2018, at 2:23 PM, Missi email@hidden wrote:
Thanks Walter,
