Any reason why this doesn’t work anymore?
http://www.easthalldesign.com/signin.html
Its set up to link to a folder but it does nothing when I hit submit?
Password is: everglades
Tim3
(Tim)
#2
Hi Justin,
I’m uncertain how this became broken but you can fix it by giving the form a name attribute of pswdform.
Go to Page > Form Set up… and select Extended Form. Press the New… button and enter;
value: pswdform
OK your way back to the document and try the form again. It should now work as expected.
FreewayActions.com - Freeware and commercial actions for Freeway Express & Pro.
http://www.freewayactions.com
Its not working can you claify this
Press the New… button and enter; name: name value: pswdform
Cheers!
Tim3
(Tim)
#4
Hi Justin,
Yes this should work. Here’s my hand corrected version;
http://www.freewayactions.com/test/justin/
Compare your page output to this version.
It does! - But I dont understand this:
What do I enter in:
Name:
Value:
Tim3
(Tim)
#6
Hi Justin,
The name/value settings should be;
Value: pswdform
Let me know how you get on.
What do I enter in:
Name:
Value:
K - was doing this - its not working?
