I am working on a new site and would like to password protect the site while its under construction then take it off.
How can I do this?? Thanks teach!
Open your Cpanel> under security, there should be a folder icon titled ‘password protect’ or something similar. Open, follow the instructions to password protect your root folder and you’re done.
Hope this helps
Dick
On 30 Aug 2010, at 22:29, Carla wrote:
Hey all
Hey all I called GDaddy again because I was sure that they must have the capability. and they do…the tech support I first spoke to had the wrong info
so once I make folder I can password protect it… I was going to have another hosting like I needwebhosting.com as I do for one of my other sites, but I will need more phone support in the US.
