I decided to give Perch a try. I have my SQL database setup and Perch seems to be up in running. I’ve added this code to the page using the Before markup option.
The problem is I don’t know exactly where to add this code:<?php perch_content('Intro');?>
What I did is I selected an HTML Item from within Freeway Pro, then selected “Extended”. In the Extended dialog box I added an “Intro” div with the value “<?php perch_content('Intro');?>”. When I add my content to the Perch control panel and reload the page no content is displaying, so I’m clearly doing something wrong.
Check to see what character set you have set your page to, and your database. MySQL by default uses something similar to Windows Latin, and you have to manually tell it to use Unicode. Your page will most likely be in Unicode. The database will deliver text in a particular character set, and unless it matches exactly the text that the database is sending, you will see what you describe here.
Try fooling with the character set in Freeway first. Try the various encoding options in the Export tab of the Page Inspector. See if any of them work.
If you can’t get it to go, then you’ll have to go back through the database settings and see if you can trick it into using a different charset. You may end up re-entering your data if you go that way. You can’t just convert it in place.
