[Pro] permanent top layer
Is there a way to keep my menus (on a maser page) permanently on top of everything else, in particular items that are subsequently added?
Here is the site in question: www.vipl.ca
This will, I think, require that CSS Layout button is on when you create your page. Or at least the item you want to influence is a layer.
Select your menu item. Item>Extended
Select
and New to create a new name value pair
Name: z-index Value: 99 (or another high number)
The z-index determines the stacking order of items, the higher the number the nearer the top of the pile.
Do it on your master so it affects all pages where the menu appears.
Well that worked like a charm! Thanks you so much for your assistance.
Larry Wilson
