Hello guys,
I’m not sure if this is a bug or the way a constructed my form. Once the form is filled up and click submit button, it sends the data like nothing is wrong -success page; however the email I set up as recipient is not receiving any emails or feedback from the form. Any ideas why this is happening?
here is a link to the form:http://rgcreative.com/50years/reserve.html
Any help is appreciated, cheers.
Carlos
Is there more than one email address the form is sending inquiries too?
I have found that attempting to send the form to multiple email addresses can cause it to not function at all. I’ve never had a problem with it just sending the form to one address.
Hello again
I was trying to figure out what was the problem with my feedback form and this is what happened:
In my previous post I created the form using a table approach and all I got was the success page notification but no emails - recipient email- received.
In this post: I recreated the form starting with individual html items, checkbox,field text and button. Once the form is filled out and click submit, it downloads the page’s name (code type) with a php extension. No success page nor Error page only the download.
Does anyone have a clue why this happened. Anyhow, I’ll keep trying to solve why the form is still not working, but any directions or suggestions are welcome, thank you.
Carlos
Hi Curtis,
No, the form has only one email address.
A couple of questions
1 Where is your site hosted?
2 And do they support PHP on your hosting package?
Also instead of check boxes you want to use Radio buttons - this way only one can be selected at a time if they have the same Name in ‘Item Output Settings’ - 3rd Tab
Using a table is a good idea as it keeps your form elements neat if you put the descriptors all in the first column and the form elements in the 2nd (Use a 2 col table with as many rows as you need)
If you use a table then apply the PHPFF action to the table itself - if not then apply it to the page. But dont do both!
